JRscooby
Jan 30, 2022Explorer II
wa8yxm wrote:
There is still a maximum pressure.
And if the unit has a leveling valve. Well you have to override it to get the rig higher than the set point.. So with a leveling valve system the answer to the OP's question is easy: NO.
Yes there is a Maximum pressure. But what is it? the pop-off on the tank will let go before the vehicle system gets to that pressure.
I don't know anything about the OP's tool or skill set, but like I posted before;
OP, I never did it but I'm sure you could plumb in a couple of solenoid valves, 1 to bypass the leveling valve, another to block the LV exhaust, and do what you want.
38,781 PostsLatest Activity: Aug 12, 2026
