I did a few searches in this forum to see if there were any posts on towing an ML350 4 down and could not find one. Anyone out there doing it and if yes what equipment are you using ?
Definetelly NOOOOOOOOO ! i have a car that has the same tranny, for some reason if the Tx is in N and the engine off, somehow, a paw (different than the "park" one ) blocks some components inside. I learned the hard way while driving around 30mph I put the Tx in N and TURNED OFF the engine.... GRRRRRRRRRR an awfull sound of grinding!!! Inmediatelly started the engine, and braked REAL HARD! After a full stop I put the tx in P, then slowly placed in D, it worked as should... NEVER TRIED AGAIN!
