allbrandauto
Oct 15, 2013Explorer
to test a battery remove the vent caps with a battery hydrometer test specific gravity all cells should be in 1.275 range if any cell is more than 25 present off battery is bad if all cells are low battery must be charged up and retested if all cells are good battery has to be load tested hook load tester to pos. and neg. battery post load battery for 10 seconds voltage should not drop below 11 volts and volts should come back to over 12 volts quickly
38,782 PostsLatest Activity: Sep 10, 2026
