prism
Oct 15, 2013Explorer
allbrandauto wrote:
to test a battery remove the vent caps with a battery hydrometer test specific gravity all cells should be in 1.275 range if any cell is more than 25 present off battery is bad if all cells are low battery must be charged up and retested if all cells are good battery has to be load tested hook load tester to pos. and neg. battery post load battery for 10 seconds voltage should not drop below 11 volts and volts should come back to over 12 volts quickly
OP clearly stated they do not know or want to do this.They also have had 2 seperate shops TEST and confirm batterys are good.based on what thay have posted I suspect Batterys are good to go. no need to complicate things
38,782 PostsLatest Activity: Sep 10, 2026
