holstein13's avatar
holstein13
Can high water pressure confuse your Hydronic heater?
I've got an Oasis hydronic heater in my coach and today it malfunctioned. I went to take a shower and I had no hot water.
I got out of the shower and checked to see if the burner was turned on. Both the electric heating elements and the burner were set to come on but were not coming on despite the low temperature of the water. So I called Oasis.
When I got tech support on the line, the guy on the other line first had me describe the problem for him then he asked me to turn on the summer bypass loop and see if that would fire up the heater. Sure enough, it did.
Then he asked me if I was hooked up to city water. When I told him that I was, he immediately said my water pressure is too high. According to him, the Oasis is designed for water pressures under 55 PSI and if the pressure is too high, it confuses the heater.
Therefore, I screwed on my pressure regulator and have crossed my fingers to see if he was correct. So far, so good. Have any of you ever heard of such a thing?
  • Okay, my Dutch Star didn't come with a water regulator and I added an adjustable one......but your King Aire didn't come with a built in regulator???
  • On the older units, that's not an issue but on your newer higher tech version I guess it might be. Did the rep mention just what gets "confused" Tough to imagine how that could happen but he must know of what he speaketh.
