Ed_Gee
Nov 11, 2022Explorer II
bobndot wrote:
12v vs two 6v batteries
Just keep in mind that joining two 6v batts will keep the amps the same, where by joining two 12v batts, the amps will double.
The above is misleading, and possibly erroneous. The capacity of a quality GC2 Six volt battery is generally around 220AH, where the capacity of a good 12V battery is around 100AH ... so you will end up with slightly more capacity with the heavier duty two 6V batteries anyway.
