maxheller
Oct 02, 2023Explorer
Disable alternator charging of house battery
Hi everyone,
Does any of you have any experience in how to install and wire a manual switch to disable alternator charging of the house battery via a latching relay? I have a Trombetta Latching Relay (684-1261-212) installed in my 2023 Thor Chateau 22E, which is controlled by Intellitec Delay Relay (00-00629-120). If believe this is a common setup.
I would like to be able to disable / enable the alternator charging (and emergency start in the other direction) via a second switch. Reason for this is that I am planning to install LiFePO4 batteries and a DC-DC charger, but would not like to lose the emergency start feature.
Has any of you done this or has a good understanding on which wires need to go where into a manual switch?
The Intellitec Delay Relay (00-00629-120) has a wire that is tied to the iginition, so I was thinking about using this wire to go into a switch. Any thoughts?
Thanks.
Max
Thanks.
Max
