pnichols
Nov 25, 2022Explorer II
heyobie wrote:
Just added 2 digital volt meters to my dash. I can now see the house battery and car battery voltage levels with the engine off. When driving I can determine if I need to charge the house and monitor the alternator. Life is good
I have installed the same two digital voltage meters showing the same two voltages on the dash of our 2005 Itasca Class C E450 motorhome - all the time whether we're stopped with the engine running or not ... or traveling.
I also have a 3rd digital current flow meter on the dash that shows current into (positive numerical reading) and current out-of (negative numerical reading) the coach battery bank - all the time whether we're stopped with the engine running or not ... or traveling.
Our motorhome came stock from Winnebago wired to automatically (via a solenoid activated whenever the engine start key is turned on) connect the engine starting battery to the coach battery bank.
The two voltmeters on the dash read just about the same whenever the engine is running (if the solenoid has been activated and if it's contacts aren't too corroded). The preceding of course is assuming that the built-in generator isn't running or we're not parked on hookups.
Whenever the engine is running, the current flow meter on the dash shows how much current (positive numerical readings) the coach batteries are receiving from the engine's 130 amp alternator. When the engine is not running, the current flow meter on the dash shows how much current (negative nummerical readings) is being pulled from the coach battery bank to power the coach's 12 volt circuits. The preceding situations of course assume that the built-in generator isn't running or we're not parked on hookups.
By the way whenever we stop to gas up the E450's fuel tank, for safety I turn off the coach's 12V system switch so that the refrigerator's gas flame can't come on ... as the refrigerator's outside ventilation port is close to where I refuel the motorhome. Also after gassing up if I forget to turn back on the coach's 12V system switch (thus the refrigerator can't operate), the two voltmeter's on the dash don't read close to the same ... which immediately tells me to stop somwhere soon and go back into the coach and turn on the coach's 12V system switch so that the refrigerator can operate while we travel!
38,782 PostsLatest Activity: Aug 23, 2026
