DrewE
May 09, 2016Explorer III
Is your problem that the fan is running when it oughtn't, or that the compressor isn't running when it ought? Naturally if the thermostat is set to a temperature higher than the ambient temperature, the cooling unit should not run; and it's entirely possible (and good) that there's a delay of a couple minutes before it will let the A/C start up again after it shuts off to let the pressures in the cooling system equalize.
If you think the fan should shut off, perhaps the thermostat has a fan switch set to "on" rather than "auto." It's also possible that the fan may automatically run for a little bit after the compressor shuts down since the evaporator is still cooling for a bit...I don't recall if my Duo-Therm does, and even so it would not be a direct comparison as it's a different and older model.
