holstein13's avatar
holstein13
Explorer II
Jan 04, 2015
Can I drop someone off at Phoenix Sky Harbor in my MH
I'm 13' 4" tall, 45 feet long and tow a Ford F150. I need to drop off my wife at Phoenix Sky Harbor Airport at terminal 2 in a couple of weeks. It would be much easier if I could drop her off using the Motorhome and continue on my way afterwards.
I've seen passenger busses and shuttles at PHX the couple of times I've flown out of there but I am not very familiar with the roadways. When I looked at my low bridge app, it said there is a 9 foot bridge at terminal 3 but I'm thinking that I don't need to go by terminal 3 anyway.
Does anyone know if my goal is possible?
On edit 01/21/14. I successfully, dropped off the family at terminal 2 this morning with only one minor problem. I decided to drop them off in between the shuttle busses where drop-offs are allowed rather than risk the inner lanes closest to the terminal. Although it worked flawlessly, a bus blocked me off right as I was leaving because he was trying to angle in front of me to park there. I waited about 90 seconds and he moved on. There was no danger of hitting anything overhead and all lanes were plenty wide enough for my 65 foot length. All merges were easily executed and the reduced speed at the airport helped as well.
As someone mentioned in the comments, there are several signs warning that the maximum height for vehicles is 14 feet tall.
  • I took my large toyhauler through there about 4 years ago. It was 13' tall and fit just fine through there.
  • Here is the number for Sky Harbor parking (602) 273-4545. When I had to drop off family three years ago they were very helpful.
  • mikey52 wrote:
    There used to be a shuttle from the train station at 44th and Van Buren to the airport. You could drop her off at the station and she could ride the shuttle into the airport. It has been a couple of years since I used that route, by now one of the trains may run into the terminal, but that would keep you from having to go through the airport with the motorhome and get her to the terminal safely.
    trains go to terminals now
  • There used to be a shuttle from the train station at 44th and Van Buren to the airport. You could drop her off at the station and she could ride the shuttle into the airport. It has been a couple of years since I used that route, by now one of the trains may run into the terminal, but that would keep you from having to go through the airport with the motorhome and get her to the terminal safely.
  • I'd also be concerned that they'd let an RV thru the airport. Since 9/11 there's all sorts of rules about stuff like that. Personally I'd find a Walmart close and call a cab. But I don't like driving a car thru the airport but then again I'm in Atlanta.
  • I use Sky Harbor all the time. I don't believe there are any low clearances on the main road through the airport that would preclude you from driving through. Remember that large sized buses drop off and pick up passengers there all day long. You might have a problem getting to the curb to drop them off, but as long as they don't mind walking a little bit, I think you would be okay. If you can't find a place to pull over, you could take gcloss's advice above.
  • I've to Phoenix Sky Harbor a few times. Not sure it is doable with.your rig. The airport has a very good car rental facility outside the airport with free shuttles to the terminals. You could probably drop off at the car rental facility and then they could take a free shuttle to the terminal.
