wa8yxm
Jan 20, 2017Explorer III
The full answer is rather complex but the short answer is YES. Been there, Done that in fact. (Well mine was 20 amp...)
By CODE, any "Modern" outdoor outlet is supposed to be protected by a GFCI. some RV's do not play nice with GFCI outlets. If this is the case it won't work, It will. however, be safe
You can charge batteries, "Chill out" the fridge (run it) but may not have enough power for air conditioners or water heaters.
38,783 PostsLatest Activity: Sep 09, 2026
