ECones
Dec 28, 2015Explorer
ericsmith32 wrote:
ECones.. you were thinking along the same lines as we are! I winterized in November which was way too early. We dry camp more in the cooler months since it's easier and don't have to run the AC.. so no showers unless we stay at a campground. Our tanks are also underneath but all of them have heating pads.
If we go anywhere else before March I'm going to clean out the pipes and refill the water heater. I'll leave antifreeze in the fresh water underneath. We have 3 big 5 gallon water jugs and will suck the water from those. On our Jayco it has that feature, not sure if all them do. Have to find a electric heater that goes lower than 60 though.
Water tanks are fairly cheap so going to put one under the dinette or the back sofa's this year. Winter is the best time to camp!
Eric, regarding finding a heater that goes below 60, I plugged them into Thermocubes <-- click.
I've got two 1500 watt heaters plugged into them in plugs that I know are on different breakers. If either gets below 35 degrees, that heater will come on until that Thermocube is about 45 degrees.
38,707 PostsLatest Activity: Feb 28, 2025
