msmith1199
Jan 20, 2015Explorer II
etruitt wrote:
I just checked the window sticker/spec sheet and it lists 7000 lb hitch receiver with dual connector. Does that mean my "tow rating" is only 7k lbs or does that mean the receiver will handle up to 7k lbs hitch weight? Probably sounds like a stupid question but if I knew the answer I wouldn't ask.
That's the capacity of the hitch not the vehicle. You need to find your Combined Gross Vehicle Weight Rating or CGVWR. That will be the max weight for your fully loaded motorhome and whatever it is towing.
38,766 PostsLatest Activity: Jan 10, 2026
