wa8yxm
Jan 20, 2015Explorer III
I do not know if the truck can be towed 4 down, Google Remco Towing and enter the truck's specs on the left frame and fine out.
IF it can (most 4WD's with manual transfer can be towed, Some others, RWD's can be modified for towing). then I suspect the truck is well under the 9,000 tow hitch rating, Do not know if the Motor home can pull that much.
Blue ox and others make Tow bar systems in teh 10,000 pound rating range
MAKE SURE YOU HAVE AN AUX BRAKING SYSTREM ON THE TRUCK so that it helps stop the consist when you stand on the motor home brakes.
And other than towed lighting.. That's about all I have to say.
38,766 PostsLatest Activity: Jan 10, 2026
