ferndaleflyer wrote:
Would you like some advice from experience? My partner has the same DP you have and tows a 30ft double stacker with a dragster, a door car, a golf cart, and lord only knows what else in there and no WDH. 10,000lb rated hitch. I myself have a 32 ft tri axel trailer with a door car and an ATV towing with a Monaco with a 10,000lb hitch and no problem. I have used this set up behind 2 other DPs as has my friend. I travel about 20,000mi a year and he may rack up more going to races here in the East. If your hitch is rated at 10,000 a little extra tongue weight won't do anything but help control the trailer....to little and it will wonder all over the road. Hope this helps
Has your partner ever weighed his stacker trailer fully loaded and also tongue weight. It sure sounds like he would be over weight on both.
