valhalla360
Dec 19, 2020Navigator
Check the oil spec for the generator...as long as you choose an oil of equal or higher standard, you will be fine.
Diesel oil is typically holds a higher end spec and will cause no problem in a generator. The other way around usually doesn't work.
