gutfelt wrote:
... it wont have anything to do with the boost on or off because they would get channels on one side or the other ;; even without scan u will get usually one or two channels...
Really can't make a blanket statement like that.
If I don't switch the booster on I get ZIP, ZERO, NO channels.
>Each coach wiring can be different.
If I do not do a scan I get NO channels.
>Each TV can be different.
AND
I have had the circuit board where the antenna attaches to go out also. Symptoms where no channels.
Had that happen on 2 of the TV's. i had them replaced at a TV repair shop.....yup you can repair a flat screen TV.
