rockhillmanor wrote:
gutfelt wrote:
... it wont have anything to do with the boost on or off because they would get channels on one side or the other ;; even without scan u will get usually one or two channels...
Really can't make a blanket statement like that.
If I don't switch the booster on I get ZIP, ZERO, NO channels.
>Each coach wiring can be different.
If I do not do a scan I get NO channels.
>Each TV can be different.
I understand your opinion for sure;; two reasons I suggested what I did is because the OP knew about scanning so one assumed he tried that on both sides and that's why I suggested wrong input: based on his reply and said booster was on then its rather obvious he never tried scanning (assuming he was in a area that would get a OTA channel
second off I have owned a few MH and have worked on plenty and have helped out many a person whom got into same trouble as OP but I have always found scan or no scan one will get the odd channel with out scanning so Ok agreed I wont make it a Blanket statement;; just always been my experience
