rockhillmanor wrote:
lots2seeinmyrv wrote:
Usually there is a 12 volt outlet where the TV is plugged into. By that area...there is a little switch you flip to change from "air over to cable".
Little red light may be on where the switch or button is...and very hard to see it.
Then do the channel scan on the TV set.
X2
They are all different looking in each coach. Mine is hidden in a dark cabinet so you couldn't even see that there was a teenie tiny switch to turn on for the booster for the antenna. And the red light was just as tiny. :R
Here is one example of what it looks like.
Thank you for posting the picture...so it seems it was the antenna switch I mentioned.
