Pangaea_Ron
May 05, 2013Explorer
Can't fill gas tank in CA... nozzle won't fit into opening.
I tried getting the gas nozzle inserted into the filler tube, and it won't fit. It seems that the nozzle with vent recovery system will not pivot forward enough to allow the nozzle to fit into the lower opening. I tried 5 gas stations (Shell/Texaco/Texaco/Independent) in Eureka/Arcata, CA until I could finally get one to fit (Circle K/76). The upper fiberglass trim around the door for the fuel tube is part of the problem.
In 2 of the gas stations I could hold the vent recovery cuff up and lightly press the handle to allow a minimal amount of fuel into the tank. It took several minutes for 5 gallons. In 2 gas stations I could not even get that far.
I have seen an adapter here on RV.Net that was made from a oil can spout, but can not seem to find it now by searching. Some motorcycles apparently have a similar problem.
Any thoughts.
Any thoughts.
