I really don't know what you people mean by "pushing it around the camp ground". In the 7 years I've owned a motorhome I had to un hook 3 times. The words I use are "pull through" works almost every time. When it doesn't I back it in. My DW can pull the toad on the dolly and get her strap on then hook the safety chains while I put my strap on then go tighten her side and off we go. Trust me its not the problem people make it out to be. I can trade toads and not spend a nickel to buy a new plate and have it installed. I don't have to stop and crank the toad every 2 hours to lube the trans, I don't worry about unlocking the steering or running the battery down or hooking up some expensive brake system. Get a Demco with surge brakes and forget it. Even two 70 year olds can handle it.
