nbking's avatar
nbking
Carbon Monoxide Detector
The carbon monoxide detector on my newly purchased motor home expired in 2009. I want to replace it.
Is there a difference between a regular carbon monoxide detector and one used in an RV?
The one in the motor home now is a Costar Model 9RV. It states:
"Single Station Carbon Monoxide Alarm. Also suitable for use in Recreational Vehicles"
It is the round shape that looks the same as the smoke alarm rather than one installed lower in the motor home. It was installed in the ceiling.
Could I just buy a round carbon monoxide detector from Home Depot and install it?
  • Don't believe any of us, read the installation instructions that come with the CO detector.
  • So much mis information. People should really check what the pros suggest is the best placement for carbon monoxide detectors
  • rwgeiser wrote:
    Carbon monoxide is lighter than air, propane is heavier than air. Carbon monoxide rises, propane settles.
    In other words, don't install the CO detector near the floor.
  • Carbon monoxide is lighter than air, propane is heavier than air. Carbon monoxide rises, propane settles.
  • My CO detector has a non replaceable 10 year battery. By that time the sensor is no good any more so is time to replace the whole thing anyway. Kidde says the batteries will probably last longer with the cold weather storage so I should pay attention to the expiration date and not wait for the low battery alert. Pay attention to that if you get something similar.
  • I use a battery powered one from Lowe's that was cheaper than the RV versions and have complete confidence in it. Just make it a routine to replace the battery.
  • It is battery operated.
    That is what I thought too. They usually mount them low near the floor which would be the first place for carbon monoxide to collect. By the time it reached the ceiling, it may be too late.
    However, it was installed in the ceiling.
  • Is it 12VDC or battery powered?
    That will make the only difference.
    BTW ceiling is absolutely the wrong place for carbon monoxide detectors.
    Smoke alarms, yes, ceiling mount.
