CLIPPERGUY
May 12, 2015Explorer
Funny you mentioned leak from rust. While looking at the unit, I noticed that water is accummalating at the rear of the unit where the fan turns. I don't see a drain but will look closer and drill a small hole to allow drainage if a drain port doesn't exist.
At any rate, while the compressor is on, I noticed what look like bubbles from the pool or water. I attributed it to the fan turning becuase the pool is at the base of the fan blade. I neglected to turn off the compressor and see if the bubbles still appeared. I'm going to do that before he comes to see if I have leak in the system. That may save him some troubleshoot time.
I suspect if there is a leak it wouldn't be cooling and the freon would have leak during a single use. I noticed the noise a few trips back.
I will report out the results
