j-d
May 17, 2015Explorer II
That approach oughta get it! Dometic and Coleman/RVP/AirExcel seem to be the choices these days. There's a Chinese knockoff called Advent that's showing up as OEM on some RV's. Cheaper than the two name brands, no less.
We've had only two RV A/C's, both Coleman Mach. They have cooled well and lasted a long time. Interestingly, one of our resident techs liked Carrier above the others, while they were still in the RV A/C business.
For those watching the capacitor discussion, I was able to find a single 12.5-mfd capacitor that could run the fan. Or if the fan was running OK, plenty of 45+5 caps where only the 45 could be used to run the compressor. All that would take is a jumper between the common terminal of the two.
BUT!!! Capacitor was only an item-of-interest. We never confirmed that it was the actual cause of the noise, and we agreed from the outset that replacing the compressor means replacing the whole unit.
