gtschulz's avatar
gtschulz
carrier air V
The Carrier air V in my 2007 Damon Tuscany requires repair The blower motor bearings are seizing. Any ideas on replacing or places to get it repaired?
Thank you.
Jerry
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have a spare blower or two for Carrier.. (If you are near Upstate SC no charge) run around 200 to replace with new or as somoene said find an Electric motor shop and get bearings replaced for less.
    Carrier is out of the RV A/C business
    If you decide to replace there is a 3rd party that makes an adapt-a-kit to put a coleman A/C on a carrier lower unit.. Well it's a hybreed lower unit (you move the carrier electronics to a new lower plate)
    And Advent Air (China) makes one that's even easier to swap but if I have my choice I'll go with coleman. (AND i WILL) I have one of each and like the coleman better.. However the coleman does have an issue I have finally identified (Will get fixed later)
  • Almost any electrical shop should be able to change the bearings, if you remove it. A new replacement should be available from Graingers.
