skid4245
Nov 01, 2025Explorer
Carrier Air V
I'm in Wisconsin right now and my Carrier Air V furnace has stopped blowing hot air. It starts up properly but just doesn't blow hot anymore. I have plenty of propane and all my stove burners work. W...
If the furnace starts but no warm air comes through, I’d check the sail switch, burner ignition, airflow ducts, and thermostat settings since airflow or flame sensing can stop heat. I found the Carrier 38CKC060 installation and start-up guide helpful — it explains system startup, safety checks, and airflow setup, which can help trace why heat isn’t circulating.
the carrier air V is a air conditioner with a heap pump function, there for no sail switch as in a normal furnace. the guide you linked to is for a home AC unit, not a rv unit in anyways shape or form. you mentioning a sail switch and burner while linking to that manual makes me wonder about a few things myself and wonder how davidkoperty would even like such a contradicting post.
