k9-keno's avatar
k9-keno
Carrier to Dometic conversion
So I finally get my Dometic roof unit dialed in with my Carrier base inside. So I thought. Ac unit runs fine then maybe 3 days into our trip the unit shuts off Carrier board blinks 5 times. ( I think high voltage) is that code. Go outside pull power (yes on a surge protector)and disconnect batteries. Unit clears error from memory ran fine for a day or 2 did the same thing. My rear Carrier unit top and bottom it's all Carrier does not have any issues. I found only one post on the internet someone else was having this problem but nobody had a solution. Any thoughts on this? I checked my power coming in its fine. Am I just going to have to bite the bullet and buy a dometic bottom inside and thermostat?? I am I right saying the board is just not liking the Dometic at some points??? Thank for any input I know the Carrier AC issues since they went out of the RV business have been around. Thanks!!
  • wa8yxm wrote:
    The manual says:
    1. Check 115 volt AC power source
    Momentarily disconnect 12 VDC power source
    Disable compressor malfunction test switch.
    Check AMP draw.
    Check ? T
    Sounds like one of the last 3 might be the issue... Delta T means difference in temperature by the way (the last item)
    Thanks. The unit is brand new. I'll check the items you mentioned. Im thinking maybe they don't communicate well Carrier/Dometic. Rear Carrier not giving any fault codes.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The manual says:
    Check AMP draw.
    Check ? T
