ron_dittmer
Sep 22, 2020Explorer III
Johnny Dearborn wrote:Smart Move!
Thanks for all of the responses. I’m going to try trailering to start and the see how it goes.
Our rig is very similar to yours in configuration, a 2007 E350-V10, the 158" wheel base, and 23'-8" over-all length. Our fresh water tank rests against the back wall. When filled, the front lightens up. A 400 pound motorcycle plus the hardware to hold it would be 3X my situation, so much worse.
Another matter to consider is your frame extension and hitch in back. Your rig is 20 years old. That implies the hitch is rated to pull 3500 pounds, and the tongue weight is rated at 350 pounds. Add in rust and fatigue, implementing your idea will likely become a serious matter.
If you have a place to store one, consider a small enclosed trailer, one that could also store other items you'd like to bring or transfer items inside that are typically in your way. U-Haul rents a real nice tiny enclosed trailer that might fit your cycle and more. Try that one on your first trip. If you like it, buy one like that.
