fishingbob61's avatar
fishingbob61
Cat 300 running hot on gradea
In 90+ weather when pulling a long grade my 05 Bounder 34m with a 300hp Cat will run in the hot on the guage and the yellow light comes on, I will down shift and let up on pedal. When top of pull it cools down. I had it at Freightliner and they cleaned out the rad and cac and adjusted the water pump belt, helped some. Any thoughts?
  • Probably not what your looking for but on my older CAT (3176B), I always tend to run in 5th gear in order to keep my hydraulic Fan running at a higher speed. In my 15 year's of ownership and traveling in the worst of heat(110+ degree's), it has never failed me. I only release it to 6th gear on the level-est of highways.
