aztortuga wrote:
Is it possible that your primary fuel filter is plugged? The one mounted on the engine. I believe the filter with the water separator is a secondary filter although it is installed in the first position between the tank and then the engine. I would change out this primary filter and see how it goes.
The filter shouldn't be plugged, but that's one of those things you never know until you try. I have new filters here, so I'll try that tomorrow. Also, I know that my power supply wires are good, but I haven't started cleaning grounds yet. I'll also try that tomorrow.
The coach is parked in my (rented) covered storage area, on gravel, so it's a pain to get under. I do have a throw rug I can use to lie on while checking the grounds.
The fuel filter is accessible by taking off the rear cover under the bed, so I can change it from above. I just need to put a drain pan under that area so I don't stink up the storage lot with a bit of spilled diesel.
Whenever I get this problem resolved, I'll post the solution here. Thanks to all of you for your suggestions.
