tiffinboy wrote:
Mr.Mark wrote:
tiffinboy wrote:
Diplomat Don wrote:
tiffinboy......Mine is a 36' weighing in at about 29000 pounds. I run about 1490 rpm at 59 mph. My Monaco is a rear radiator and I replaced the engine fan with a Source Engineering fan which uses less power and increases HP by 25. I also run a DiGiCr engine chip which has provided a very noticeable increase in mileage. I add OptiLube at every fill up and I drive using my VMSpc computer. I'm constantly watching my instant mpg and change my driving habits as mpg changes, such as wind or hills.
I have a SmartWheel and do 90% of my driving by never touching the throttle pedal as I hate the feel of it. I enter freeway on ramps at a reasonable speed unless traffic requires a faster entry. Once I hit 45 mph on a ramp, I set the cruise and then throttle up a mile per hour every second or two using the SmartWheel. All of my freeway driving is done by thumbing the cruise control up and done with very little use of the throttle pedal.
If I take a short trip to a local park (95) miles away, I only average about 8.5 mpg since there is so much starting and stopping. The long trip we took was literally 6000 miles of highway driving at speed with few stops and starts. I track my mpg via my VMSpc and my wife does it on paper at every fuel stop. On trips that I don't tow where there is a lot of nonstop highway driving I can get 10 mpg.
I've been on this forum for over 8 years and have read a lot about the fuel mileage people get. I would have to say that yours is low for the speeds you're driving. I would question your driving habits. Your mileage is closer to what the people who drive 65-70 mph are getting.
go from reno to bishop and back and I bet u get 5.5.in what way does a smart wheel help fuel mileage?
I actually use my Smart Wheel the same as Diplomat Don.... set the cruise and bump it up slowly (if traffic allows). I, like Don, don't like to use my throttle pedal. Our coach weighs just over 40,000 lbs. and we average about 7.0-7.5.
When fueling, I always tilt the coach with the airbags towards the passenger side so that I can fill it to the brim. I can go at least 100 miles before the needle moves off of full.
MM.
ok u say smart wheel(wrong term) I simply say I use cruise control
I average 7.8 last trip lots of passes.I looked at the mileage chart and fuel used of the Cat 425HP friend and he got 9.7 from Edmonton to las vegas
Tiffy, I was using your term 'smart wheel' but we both know we are talking about the cruise control. I certainly wasn't referring to blinking my marker lights! LOL!
Over the 65,000 miles I've driven our coach I check the fuel mileage with pen and paper. I've gotten 4.5-9.8 mpg (we tow 99.9% of the time and I usually travel at 58-60 mph). I also make note on the receipt of how much generator time and or Aqua-Hot I've used if I really want 'real' numbers.
Mark
