wolfe10
Sep 17, 2015Explorer
Not a bad idea after removing the old gasket to use a sanding block and some wet-dry 400 grit sandpaper to "dress" the mating surfaces. Just put paper towel in the thermostat housing to so metal gets in.
This will tell you very quickly if both surfaces are true.
38,782 PostsLatest Activity: Sep 10, 2026
