We Cant Wait wrote:
DownTheAvenue wrote:
kemer wrote:
I know you can do individual tires(all 4 corners),
No you can't. You will get axle weights listed as steer, drive, and trailer. With a motorhome, you drive until the front axle is on the first scale and the rear is on the second.
DownTheAvenue; YES you can get 4 corner weights if you use the procedure I described above because I've done it before.
Like most everything...it depends...the CAT scales at Pilot/FlyingJ stations are elevated making it impossible to four corner weigh. Only if the scale is ground level can you follow that procedure. Also, that procedure is iffy at best as any deviation in ground level will skew the results......Dennis
