bhivetravels's avatar
bhivetravels
Cat Scratch Door Trim Laminate
We accidentally closed the cat into the half bathroom. While our cabinet doors are all wood the door to the half bath has these little wood block like decorations that are covered in a wood like laminate. Well sitting by the door The cat decided to sharpen her nails against the fake wood grain and now it looks terrible. I've tried a bit of glue but there are still pieces missing and I've looked for matching wood grain but can't seem to find anything. Any other suggestions?
  • magnusfide wrote:
    What I would do is remove all of it and replace it with new instead of trying to match it. You can easily find replacements at Home Depot, Lowes or other hardware stores.
    Herself's philosophy is if its damaged, redecorate! Over the years I found her way is cheaper than trying to buy an identical part through the manufacturer.
    Probably my best choice. Thanks all I'll give this a try.
  • Pogoil wrote:
    2nd the Old English. They make a light and dark version. You choose what is best for the wood color.
    We also use it each year on our oak cabinets. Makes them glow and preserves the wood. Our cabinets have a very light sheen on them and the product appears to soak into the wood.
    Pogoil.
    Tried the old English, does not stain or stick to the fake trim
  • sailor_lou wrote:
    I'm a little confused as to what was damaged. If it is the door trim, I would do as magnusfide suggested and replace the trim with real wood. If it is the door, you can either replace the entire door (provided you can find one the same size) or buy a sheet of wood veneer. Veneer can be purchased in almost any wood type, in various sizes and can be glued to the door surface. Some veneers are supplied with the glue attached and can be bonded to the door using an iron. After the installation, it can be stained and finished to match the existing woodwork. Good luck.
    Lou
    05 Travel Supreme Envoy
    They are small squares, six of them, tacked on to the door.
  • 2nd the Old English. They make a light and dark version. You choose what is best for the wood color.
    Pogoil.
  • Try using some Old English first....see if that makes it acceptable. Cheapest attempt.
    If that doesn't work, there are several repair 'kits' available such as Amish Milk Cleaner and 'N Hance available at Home Depot. N Hance works pretty well.
    I wipe all my wood down with Old English every year during my annual maintenance. Makes it look good all year with minimum effort......Dennis
  • I'm a little confused as to what was damaged. If it is the door trim, I would do as magnusfide suggested and replace the trim with real wood. If it is the door, you can either replace the entire door (provided you can find one the same size) or buy a sheet of wood veneer. Veneer can be purchased in almost any wood type, in various sizes and can be glued to the door surface. Some veneers are supplied with the glue attached and can be bonded to the door using an iron. After the installation, it can be stained and finished to match the existing woodwork. Good luck.
    Lou
  • What I would do is remove all of it and replace it with new instead of trying to match it. You can easily find replacements at Home Depot, Lowes or other hardware stores.
