TimfmCT's avatar
TimfmCT
Catalytic converters for 2005 workhorse with GMC 8.1 vortec
Our 2005 Tiffin Allegro has the GMC 8.1 on the workhorse chassis. It's got 58,000 miles on it. We've had it for 6 years. Last year we replaced the transmission cooler assembly (rusted out) this year we replaced the oil pump and had to replace all the brake rotors and pads etc.due to rust.
We're feeling although it was expensive we should have a pretty sound rig and plan to keep it.
Today while trying to repair the Kwickie (sp) steps I noticed a piece of rusted outer layer of sheet metal hanging off one of the mufflers.
I'm not sure how expensive mufflers are but it appears that they'd have to be cut off etc. IE not a DIY job. Are there many layers of metal on a muffler? I'm wondering if wrapping the rusted one with sheet metal would help it last a bit longer before having to replace it - - or probably both of them.
Hope this doesn't sound too silly. I'm just a bit bummed.
  • Many mufflers have had their lives extended by wrapping them with sheet metal. The problem is that since you seem to have a rust problem in your area, the inside muffler baffles can also rust and break loose. When this happens it can increase the back pressure in the muffler which can cause poor performance/fuel mileage and may eventually cause engine damage.
