- Old-BiscuitExplorer III
John&Joey wrote:
If you want to do a very good job and ensure no water gets to the formica (I'm guessing that's what you have) and swells it, then pull the sink , clean the area, and lay down some Butyl tape. Remount the sink and remove the excess Butyl as it squeezes out.
X2 - John_JoeyExplorerIf you want to do a very good job and ensure no water gets to the formica (I'm guessing that's what you have) and swells it, then pull the sink , clean the area, and lay down some Butyl tape. Remount the sink and remove the excess Butyl as it squeezes out.
- yrusosloExplorerUse a latex base, so you can make a nice bead and it cleans up with water.
- super_camperExplorerI wouldn't use any caulk for this application. Depending on your type of mount the sink probably has a layer of silicone between the sink and counter, no additional caulk is required. Scrape off the build-up and clean well.
- TucsonJimExplorer IIWhat color do you want? There are lots of possible solutions from clear silicone to colored latex. Most any will work. Check with your local hardware store.
38,778 PostsLatest Activity: Jun 05, 2026
