gbopp wrote:
It's not necessary to remove all the old caulk. Just get the loose stuff, clean well and apply the new caulk. Dicor self leveling works great on the horizontal areas, like you are planning.
Use a hair dryer or heat gun (on low) with a plastic scraper to remove the old caulk.
After you recaulk, I would apply a strip of Eternabond. Clean well before applying the Eternabond and use a roller. I like a steel roller, some like a wood roller.
Which ever one you chose, press hard and get a good contact. The Eternabond will last a long time.
Caulk under the Eternabond is what I use on our 96 Southwind. I think it's a good idea.
I messed this post up. :S
