azrving
Oct 26, 2017Explorer
Did you change any of the linkage or spring settings? Was there a very thin spring that covers the linkage and hooks into the arms? On some engines that spring takes the slight slop out of the linkage and is important. If the fuel supply is good and the carb is new/good then you may have a gov issue. If you choke it slightly and it smooths out it may be a little lean. If the carb is new we would assume all is clear inside it yet a too low float level may affect it.
38,770 PostsLatest Activity: Apr 12, 2026
