hittingtheroada's avatar
Jan 12, 2014
Converter Causing Generator Surge
I have a 5th wheel with a Progressive Dynamics Inteli-Power Converter. When dry camping we use a Honda 2000 generator to recharge the batteries. Lately when I start the generator in the morning and the converter goes into the boost mode of 14.4 volts the generator will start to surge even without the RPM's increasing. I have to use the remote pendant to put in in the normal mode of 13.6 volts for about an hour then it can be placed in the boost mode and it will run normal. I have 2 generators and it happens with either and also when the 2 of them are hooked together with parallel cables. This has never happen in the past. A technician at the company said it was impossible for the converter to cause this and it has to be the generator. One generator is brand new and the other almost new. I am leaning toward a new converter but before spending the money would like advise from someone knowledgeable
on the subject. Thanks.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
