Doug156
Dec 17, 2013Explorer
CB in a Class A
I am thinking about putting a CB radio in my Class A. Any suggestions? How do the portable ones work? Thanks
mowermech wrote:Your right it was a 10 meter set, 5 watts, I had it tweaked at my radio shop to 16 watts, and I had another 144 channels installed (we called them funny channels) and most of us truckers spent most of are time (99%) way up on one of those channels and I don't recall ever hearing anyone else on that channel. It was a real joy talking with all my friends on that channel thru out the night (I worked the overnight shift)! And you can call it what you want I don't care!! I least we didn't have to listen to all that filth from the CB Base Stations on those common channels.
" I had a 10 liter CB that was tweaked, had funny channels and I had a 250 watt amp that I used for emergency purposes only. One time there was an emergency out in the wilderness and my cell phone got no reception! I was in Washington State, I turned my amp on (hooked up to my C.B.) and got ahold of a gentleman in North Las Vegas, NV. and he called the Washington State Patrol for me! C.B.'s are a very useful tool when used properly!"
"10 liter"?? I presume 10 METER was meant.
If so, while it could be tuned to the 11 meter (27 MhZ, CB) band, it was illegal to do so.
"very useful tool when used properly!"
Right. Using a NON-type-accepted radio, at illegal power levels, is "proper use".
True, it WAS an emergency, and in theory anything goes in an emergency. I could probably get away with using a 5K amp under my General License in a true emergency! Not that I would ever have one of the fool things!
