Rolin
Jul 21, 2016Explorer
I went to a Ham Radio shop, found a hood mount...really a fender mount as it bolts to the fender using a metal bracket so it has a good ground plane. It actually bolts to the fender such that part of it is covered by the hood when the hood is closed and sticks out so that the antenna can bolt to the exposed part of the bracket. Then we used a 4ft fire stick antenna with some a small diameter antenna cable....forgot the size rating. Nice easy set up and easy to route the antenna cable into the cab to connect with the cb.
