bukhrn
Nov 19, 2016Nomad
Ceiling Replacement
I have a Forester with the Soft Touch Ceiling, due to leak damage,(the roof has been repaired) I need to replace the ceiling in a couple areas, when I pulled the soft ceiling down, some came off pretty easily, other big areas, the vinyl fabric came off, leaving the foam backing firmly in place.
I've tried scraping it with a wide putty knife, and a razor type scraper, both to no avail, is there a chemical that will dissolve this foam, or at least make it easier to remove, this is Not the same type of foam used as carpet backing.
Has anyone ever tried to replace a Soft Touch ceiling?
