JCMack's avatar
JCMack
Ceiling water stains cleaning
The ceiling on my 06 mountain aire has some water staining on the ceiling. The leaking areas have been repaired by the previous owner.The ceiling in my couch is like a foam backed vinyl. Any suggestions on what I should use to remove the stains. Thanks
  • The best product I have found (and I have tried alot of them) is Floex You can buy it at Lowes in a spray bottle. I have removed every stain I ever put it on. A man and wife that restore headliners for a living gave me that tip.
  • I have had good luck spraying vinyl/plastic with stuff sold at auto parts dealers, depends on color and amount of surface you have to cover.
    bumpy
  • OhhWell wrote:
    You certainly can't drop a sentence like that and expect people not to ask. The imagination strays to feats of impressive pressure.
    or impressive length
    bumpy
  • If it was the type of ceiling stuff like celitex in a house, you could take a sponge & dip it in some clorox, squeeze it out & dab the sponge on the stain area & it would bleach the stain out, but being vinyl, dont know if it would work or not.
    Worth a try & if it works, would be good for all of us to know.
    Neil
  • donn0128 wrote:
    Bumpyroad wrote:
    donn0128 wrote:
    Had some urin stains on my ceiling at home (dont ask) and i tried a two part carpet cleaner containing oxy clean and it worked miracles.
    sorry but I gotta ask. :)
    bumpy
    You can ask, but it does not mean i will tell you
    bumpy
    bumpy
  • Had some urin stains on my ceiling at home (dont ask) and i tried a two part carpet cleaner containing oxy clean and it worked miracles.
  • I have used "Insta Gone", a spray product from Amazon.com...worked great.
    Try on a small area first.
    Bill
