burlmart's avatar
burlmart
CEL After Failed COSTCO fill + OBD II Scan
In the past, the CEL came on maybe twice, and we fooled w/ gas cap and within a day, light went off. Looks like it wants to stay on
tho not blinking. It came on after COSTCO pumps were under too much pressure or something, and gas would not go in the 3/4 empty tank. We went to a Shell station and it looked like we were gonna have same issue (pump stops almost as soon as you pull trigger to start), but it started pumping and filled tank. Noticed CEL on next trip. Have filled it normally once since, but lite stays on. Running smooth, otherwise.
1) Are there any unique notices a 6.0L "05 Chevy would give at 42.5k mi?
2) After gas caps, what is a common cause of CEL?
3) If Autozone lot looks too small or they no longer scan vehicles, which of these scanners would you recommend:
http://www.autozone.com/test-scan-and-specialty-tools/code-reader/actron-pocketscan-code-reader/603853_0_0/
http://www.harborfreight.com/automotive-motorcycle/diagnostics/can-obdii-code-reader-with-multilingual-menu-98570.html
Thanks for your thoughts.
