oldave
Apr 16, 2021Explorer
On my 03 Windsor, the tank unit is accessible behind the pass side fuel door.
The big door isn't made to raise like the other side but if you look under the edge there are 2 straps, detaching those straps will let you lift that door.
You'll have to prop it up, then you'll have room to work.
Take pictures and label the wires and the clocking, the screws are uneven.
You can go ahead and try adjusting but I'm sure you will have to replace it.
They are electronic and seem to finally die.
