dougrainer
Apr 16, 2021Nomad
There are 2 adjusting pot screws on top the unit.
1. Is for the 1/4 tank empty readout
2. The other is for the Full to empty readout
When you adjust, you fill the fuel tank full. Once you determine which POT screw adjusts the Main fuel readout, you have to adjust clockwise or counterclockwise VERY slowly and in VERY small adjustments. It takes up to a minute for the needle to move. Very tedious process. HOW much is the needle off full when the tank is full? Doug
Here is a pic of it
https://www.google.com/search?q=adjusting+fuel+level+sensor+on+Monaco+motorhomes&tbm=isch&source=iu&ictx=1&fir=SuxkvF8zkJ_g_M%252CSYlp5ukNV16fPM%252C_&vet=1&usg=AI4_-kSA1LSz9KDIOOuiYmT49_QGYhWMIQ&sa=X&ved=2ahUKEwjNouKQ6IPwAhXSGs0KHSHLDzMQ9QF6BAgiEAE&biw=1920&bih=1007#imgrc=SuxkvF8zkJ_g_M&imgdii=vqCXpNMZzek29M
Here is a pic of it
