TomB_'s avatar
TomB_
Chaaging out artwork
Our 1999 Winnebago Adventurer came to us with a framed piece of art hung behind the dinette & we both want to replace it. It doesn't want to come off the wall, & we didn't want to take a chance hurting the wall paper, so anyone out there know how to remove this picture?
  • pegdiver wrote:
    Our 1999 Adventurer picture was held on by velco. It took a bit of both of us steady pulling from top to bottom to remove it. It is really industrial strength!
    Thanks! I thought I was going to pull the wall down along with picture.... :B
  • Our 1999 Adventurer picture was held on by velco. It took a bit of both of us steady pulling from top to bottom to remove it. It is really industrial strength!
  • Some are hung on a "V" shaped plate at the top. One "V" is mounted to the wall and the other "V" is mounted upside down on the frame. One is lowered on to the other and then Velcro is used at the bottom.
    I like the idea from "downtehroad". His way will either separate the glue or tell you where you have attachments.
  • Might be hung with some kind of mastic. Try using a length of fishing line.
    Wrap the line around each hand and slide-saw it back and forth behind the picture starting at the top and moving it down as you go.
    Worth a try.
