- Grit_dogTrailblazerI've thought about exactly that (although low in my long to do list, lol)
Have thought about just getting updated factory graphics, unsure of price. Maybe beg for a low price for free "advertising?" Was my thought.
Vinyl wrap is an option. I've thought about. ALOT of detail work around all the penetrations through the camper walls. Buy a big roll of knife less tape!
On the front cap I've thought about a "wrap" of light gauge diamond plate. On ours there's some de/lam that really can't be pressed and glued back in place, but could screw it all down so it's flush and tight and then overlay with light gauge plate. I looked it up and it was only about 75lbs for a full sheet cover for the cap. Don't remember what gauge. There's several available and not too expensive. - bkenobiExplorerI noticed there are 3 or 4 areas that have this issue, so I'll have to do something. It's all on the NL logos, so I may pull those and leave the other graphics.
Has anyone considered a wrap or new custom decals? - Grit_dogTrailblazerBeen thinking about how much the free advertising is worth to camper mfgs.
Anyone try to get a new set of decals on the cheap from the mfg?
No decals on an all white box, to me, looks like an all white box....plus there's a 99% chance that the old decals will leave significant shadowing. New ones, even if not exactly the same, hide that from casual perception. - burningmanExplorer IIThe only two good options are remove it or replace it.
Maybe Northern Lite will sell you a new one.
You’ll probably have to heavily polish the gel coat if it’s faded to where you can still see the outline of the old decal, if the new ones are a little different.
There’s pretty much zero chance they’ve got any new-old-stock original decals because of the 2014 Northern Lite factory fire. - billyray50Explorer
Grit dog wrote:
If the decal is 12 years old it’s likely pretty crispy. If not, re attach. If crunchy, I’d just scrape the whole decal
Heck the Texas sun made that Lance decal crispy and it is a 2015. Original owner might not have stored or covered it. I keep it covered storage now when not in use along with my truck from the Texas sun and occasional baseball size Hail! - KKELLER14KExplorer III went for the no graphics look on my last one for just this reason (view profile). Sorry it's now creeping up on you. As it gets older it most likely will get worse and trying to replace might be a chore if not impossible. Did it sun fade badly?...if not you might reconsider and remove the rest of what you got before it becomes a permanent image. Just my 2 cents.
- SidecarFlipExplorer IIII'm of the philosophy that no vinyl looks better
- bkenobiExplorerSo I'd it's pliable it can be reattached with one if the products above. If not, either trim or remove are the only options?
- Grit_dogTrailblazerIf the decal is 12 years old it’s likely pretty crispy. If not, re attach. If crunchy, I’d just scrape the whole decal
- billyray50ExplorerMy newly purchased 2015 Lance 1050s cabover Lance decal was peeling and I went to wash cabover and the decal came off so easy with just garden hose pressure. I am leaving it off. Looks good without it.
44,071 PostsLatest Activity: Aug 30, 2026
