robertbenita
Sep 15, 2014Explorer
I have been told that it has lasted the three years and should be flushed if I change it, or just drain and put same type back into RV. Same stuff requires the monitoring of SILICA I believe its called and I would rather go with what I perceive as being better. If I get most of it out draining and the filling with water and then draining again, won't it be ok to then put the new type coolant in?
38,766 PostsLatest Activity: Jan 10, 2026
