hotjag1
Jun 13, 2016Explorer II
coolant temperature changed
I have had this coach for about 3 years. The engine temp has always ran about 195 to 199 degrees unless it was very hot outside(90 to 100 degrees). On those very hot days it would go up to about 205 degrees and then back down to 195 when the fan kicked on.
Lately it has been running about 200 to 205 degrees on flat roads in about 75 degree weather. It fluctuates between 205 and back to 200 each time the fan kicks in. I washed the side radiator stack front and back and all I got was clean water coming out of it.
I don't think I should be worried about the 205 degree temp, but I'm wondering why it changed from running at 195 to 199 in the past and now running 200 to 205 on the same roads and conditions. It doesn't drop below 200 even on flat ground and cool outside temps.
Thanks for any ideas or suggestions on this?
